Camera not recording. All settings are the same but no recording when motion is detected.
  • 11 Replies
  • 2729 Views
  • 5 In Conversation
James1012018
One of my cameras does not record to cloud or hub .. all settings are the same as the ones that are working light comes on when motion is detected but no recording I have six cameras Can you help
11 REPLIES 11
Have you removed and reconnected the camera? Also, you show 2 different bases - 4500 and 5000 - which are you using for local recordings? Is the camera connected to that base?
James1012018
It’s the 5000 and have reset everything and the one camera still not working it’s comes up on mobile app as motion been detected but still no recording
Bring the camera closer to the hub and test. If still no good, use the Contact Support link at the bottom here.
diann
I'm having the same issue. Cameras are working, but not detecting ANYTHING or recoding.  No settings have been changed.  Rebooted the Hub - didn't help.  The little blue light on the camera isn't coming on nor does the motion sensor light come on. HELP
dcfox1
Since you say the cameras are working I assume you have Live view? Do you have a current Smart subscription if the year long trial on Ultra ran out? If you have local recording set up do you have recordings there. When you said no blue light on the camera are you trying to pair it again to the Hub?
James1012018
No live view, have full subscription,.. I have blue light on , and will record to hub but only for under a second
James1012018
I’m just thinking of throwing it out and selling all my other cameras very frustrating.. it recording to hub as I have a sad card in it . But for under a second.. it’s doesn’t record to cloud.. when pushing live recording it won’t work .. light comes on when motion is detected. I’ve had enough lol thanks
diann
Just figured that out. Got out all paperwork and didn't realize my 1 year included subscription expired 4-12-21.  Packages for the plan state  UP TO 5 CAMERAS.   We have 8.....so do I have to buy 2 packages?
This is getting very frustrating and costly.  Thanks
You purchase a 5-camera plan, and then add three more cameras.  The additional three are half the price when you have a 5-camera subscription.
For example, with current US pricing,  Premier would be $9.99 for five cameras, plus about $4.50 per month for the remaining three.  Elite would be $14.99 + about $7.50 per month.
https://kb.arlo.com/88/What-are-the-available-Arlo-subscription-plans-and-how-much-cloud-recording-i...
diann
Thank you so much for the information.
Appreciate it.
DiAnn Leman
dcfox1
@diann  Its not uncommon to forget on Ultra when the year long trial runs out, that's why I asked.
Glad it was simple.
  • 11 Replies
  • 2730 Views
  • 5 In Conversation
