Cámara don’t turn on
I need camera be fix I keep changing but don’t know why don’t turn on
If it's truly a faulty camera, there are no repairs available. You could buy another used camera to replace it but then there's no guarantees that it will work.
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to the Profile icon > Support Center > Select device > contact
Accessing Local Storage
