I’m having an issue when I connect a camera to AC power. The signal strength halves, I can no longer live stream in 4K, and the lag time to live view jumps to 25 seconds (previously was 4-5).
Is anyone else experiencing this?
Message 1 of 4
1,278
So I actually read the troubleshooting, removed the camera and added it back, functions perfectly now. Probably should have done that first...
Message 4 of 4
1,255
Hmm, I looked at the cable, it’s not an Arlo cable (I quickly ordered on amazon). It is not shielded (just has a rubber outer cover). Probably the issue (RF interference) unless anyone is experiencing this with an Arlo cord. I assume the Arlo one is shielded as I see it is much more expensive than the one I ordered.
Message 2 of 4
1,271
And I disconnected the power cord- still getting wonky signal- fluctuates between strong and good. Still a 25 second delay before live stream will start (other 2 cameras are 4-5 second) and the live feed has a good 6 second delay while playing. No 4K livestream.
The battery ran out before I installed the cord, do I need to reset something?
Message 3 of 4
1,267
Message 4 of 4
1,256
Accessing Local Storage
