  • 1309 Views
Arloultra111
My new arlo ultra has three cameras two are fine.
The third one, no matter where it’s placed or moved provides a constant static audio sound.
Is there anything I can do or is it faulty
Arloultra111,
Is there anything different with how this camera is set up when compared to your other cameras? If you place the camera with the issue in the exact same location as one of the other cameras, do you experience the same behavior? If so, consider contacting the Arlo Support Team to further investigate this issue.
Arloultra111
No difference in set up
I have uninstalled and then reinstalled changed locations and still the sound is present both live and recordings basically rendering the audio on the camera unusable. Other two cameras fine
Arloultra111,
This could indicate a hardware issue with the camera. I encourage you to contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
  • 1310 Views
