If they're constantly powered and the battery level isn't dropping, you're probably fine to leave as is. If it really bothers you, disable the camera for a while til it charges fully to 100% and then re-enable it. You'll just have no CVR or motion detected recordings for the duration. Or drag them out of CVR and have motion detected recordings until they get back to 100% and then re-enable CVR
Hmm.. strange. Can you swap the batteries between the 83% camera and 100% camera to determine if the issue is with the battery itself of the camera?
I wondered if CVR being active would divert power away from charging the battery but actually I have a Pro 2 on CVR and it charges batteries just fine. I switch the battery out of this with one that's run down via a battery only Pro 2
Accessing Local Storage
