Arlo ultra - Live stream 4k sound chopping noise.
My 4 arlo ultra cameras work pretty nice. I have a strong connection on all of them according to the app.
But one of the cameras makes this chopping sound when i live stream in 4k. This is mounted right outside my kitchen window. The other camera outside my bedroom dont make this chopping sound at all. When i stream outside my home this seams fine, but not in the 4k live stream. The videos the camera records have perfect audio though.
May I ask which troubleshooting steps you have performed so far? I don't want to suggest any prior methods you have previously performed.
If possible you can move your SmartHub/Base Station a little closer and it should help. If you have anything close to the unit as well I would suggest to create some distance since there may be wireless interference occurring.
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Accessing Local Storage
