Arlo Ultra wont connect to Arlo Pro Base Station
So I have a 4 camera Arlo Pro kit works perfectly! Bought a new Arlo Ultra, paired first time no problem and worked fine for a few months. Basically went flat, wouldn't take a charge so it was replaced with a recon unit as they do. Paired fine then wouldn't connect to the app the next time I went to view so I deleted it and tried to re-pair and nothing the app can't find it now. When I press the sync button on the camera it just flashes blue slowly then amber fast. Tried resetting base station etc . . . TIA
needforspeed,
Try plugging the camera in using the Arlo charging cable and AC adapter when attempting to sync. Do you still experience the same issue?
Hi yes does exactly the same plugged in
needforspeed,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Accessing Local Storage
