Arlo Ultra times out while loading
The issue I’m having is the camera will not play when I want to view it. It’s a black screen and times out while loading.
When I removed the camera and reinstalled, it shows a black screen when asking to position the camera. If I go to activity zones it does display a picture like it should.
I have tried the following changed the Battery, the network is strong no issues, reinstalled the camera after removing, made sure firmware is up to date
I don’t know what else to do. Any advice?
Sounds like a faulty camera to me (dead sensor?). Swap at the store for fastest results.
Sounds like you haven't tried a factory reset - I suggest doing that next. https://kb.arlo.com/000062438/How-do-I-factory-reset-my-Arlo-wire-free-camera
When viewing the activity settings, is the image updating every time you go into that section? Have you rebooted the phone and reinstalled the app as well as tried the web client?
Accessing Local Storage
