No live feed in app. App shows zero or very low charge at all times but varies. It never misses a recording. Shows all motion triggered events in timeline. Doesn't make sense.
Typically set up with solar panel. I have tried using different solar panel, different battery, different location. All has the same result.
TOMBRO,
When you say there is "No live feed in app", are you seeing some sort of error message when you attempt to live stream? Could you provide the details of the error message?
Is this an intermittent issue or does it never allow a live stream?
Accessing Local Storage
