  • 2 Replies
  • 1804 Views
  • 2 Likes
Roey1973
I bought an Arlo Ultra, updated the firmware and since then one cameras motion detection didn't work.....
Now this issue may already be online here, I'd just like to say anyone having the same issue?
If, then doing a factory reset solved my cameras problem...
I would recommend doing this and setting each camera up one by one again......
Also if you have slow Internet thing will take a moment.....
Roey1973,
Can you clarify if you're still experiencing an issue? Are you saying the reset resolved the issue you were having with motion detection?
Roey1973
This process worked for me......  i cant speak for others, i can only say for me it worked and would recommend trying if you are having issues with the the motion detection not working on any one or more cameras..
my firmware update didnt go successfully the first time but still i was able to set all the cameras up, i can only think something went wrong in between with the communication on one of my cameras.... touch wood everything seems stable.
  • 2 Replies
  • 1805 Views
  • 2 Likes
