Arlo Ulta and Pro3 cameras connect show they have strong signal yet will not allow for a live view when clicking “play” need help
now the story behind both of these cameras
they stopped working 600 days ago shortly after I put in a request with support after the long back and forth and going through EVERYTHING I was told to do the agent determined the cameras were defective
well a couple of days ago I randomly put batteries in both just to see what would happen and they turned on and I connected them to my base
so I factory reset the base and re added all of the cameras (8 around my property) again late at night
reconnected the two cameras that have been sitting for a very long time and still nothing
it shows they both have a strong signal they both even react when motion is detected yet still no live view
Instead it shows the last image they captured almost 2 years ago lol
does anyone have an idea how to “debug” these cameras with the USB insert on the side of them ?
if so how?
I would rather try to debug them then spend another 6-800 dollars on replacements
Did you also factory reset the cameras? Or just the base?
I ended up factory resetting everything
figured since I was already outside on a ladder why not
Try moving one of the cameras close to the smarthub as a test (several feet away, not inches...)
With all due respect I did that already
internet is not the issue either I have a business package for my house
what I’ve seen is that these two cameras have some sort of bug in the software that needs to be flushed out and for whatever reason I cannot get a straight answer on how to debug them with the usb input on the side of the camera
No idea if that port is enabled for debug in production cameras. Arlo hasn't (and likely won't) say.
With all due respect we only know what you tell us.
Do you have these cameras in a subscription plan? If you do, it'd be useful to know if they are recording when motion is detected.
If they are not in a subscription plan, you might consider adding some local storage, and then see if the cameras are recording to the base. There have been some reports from people saying they are getting recordings but cannot livestream.
I have both local and cloud recording and have been paying for a subscription with Arlo , hence my frustration,
almost two years ago I had many back to back support requests with Arlo “support” and have jumped through all the technical hoops
and after spending over 2K on Arlo equipment over 4 years it’s getting very old so please excuse my short answers with you
from what I’ve gathered there is something that went wrong with these cameras when they last updated and it never corrected itself so from my experience in troubleshooting tech is leading me to believe that it’s an easy debugging fix
yet everyone that works with Arlo refuses to acknowledge this
and eventually directs me to purchasing new cameras 😂😂😂😂
Accessing Local Storage
