Arlo Ultra Solar Panel Charger
  • 5 Replies
  • 2192 Views
DA56
Recently purchased the Arlo Solar Panel Charger designed for Arlo Ultra cameras. Worked well for a week or so, then noticed the camera I had it attached to had fried. So thinking it was not related to the solar panel I moved my other camera (which had been working fine) and attached it to the solar panel. It was fried within a week. Very dissapointed! Both cameras cooked. DO NOT use the solar panel!!
5 REPLIES 5
michaelkenward
Sensei Sensei
Sensei
Fried?
What does that mean?
Just another user
DA56
Does not work
michaelkenward
Sensei Sensei
Sensei
@DA56 wrote:
Does not work
I'm sorry but using vague language or general descriptions like "fried" and "does not work" provides minimal diagnostic information.
If you want help to recover your system you will have to say a lot more than that.
Solar Chargers are rarely the cause of severe failures. People mostly love them, although I don't like the fact that they aren't designed to provide the equivalent to permanent power.
The opportunities for a solar panel to cause permanent damage are close to zero. Not enough volts and amps to "fry" anything, as most people use the term. Then again, there can be problems when people who don't use them correctly.
Just another user
DA56
100% without a doubt the solar panel charger wrecked the batteries on my camera. The first 1 within a couple of weeks. The 2nd one within days. NO DOUBT. They were both working perfectly. Then after being plugged into the solar panel they do not charge even on AC - 0, fried, kaput, whatever I've done my money so I'll use whatever term I like !!!!
DA56,
I recommend that you reach out to the Arlo Support Team to further investigate this issue. You would find several options for contacting the team here:
Arlo Support Team
  • 5 Replies
  • 2193 Views
