onewontwo,
By default, the "Armed" mode will send push notifications when motion is detected. To accomplish what you're trying to do, create a custom mode that does not send push notifications when detected but is otherwise identical to the default "Armed" mode.
Now input the default "Armed" mode into your schedule during hours where you want push notifications and input the custom mode during hours where you do not want push notifications.
You can then set up geofencing for home/away using that schedule if you desire.
onewontwo,
Accessing Local Storage
