  • 2 Replies
  • 1151 Views
Oxamus
I've recently purcahed the 2 camera kit. I have it up and running with Arlo smart Premier but i am struggling to find the option where i can purchase the PVR option for each camera. I've tried on the app as well as the web but can't seem to find it.
Also, is there an option to adjust the HDR of the camera manually as i found it's not really having much success on a high contrast scene at the moment
thanks
DamianR
HDR is just on/off at present.
You can adjust the brightness.
For PVR (4k cloud recording) there are already a couple of threads with detailed instructions.
It should come up as an additional option when you are in change plan, after you select ArloSmart from memory.
DamianR
Oxamus
Yes, i figured it out, I have it enabled now.
Thank-you
  • 2 Replies
  • 1152 Views
