Arlo Ultra Cameras NOT Recording after recent Base Station Update
So none of my Arlo Ultra cameras have been recording any activity since November 5th which coincidentally is when the most recent firmware update came out for the Arlo SmartHub VMB5000 - 1.14.0.10.
I also noticed 1 of my cameras was only showing a tiny portion of the full frame. I went in and reset the video setting on that particular camera and it went back to normal. It was never set up to be zoomed in so I assume that was a bug from the update.
Anyways, does anyone have any recommendations? I have reset the base station, made sure everything is up to date. Reset router and looked through every setting. They were working flawlessly before the update. Any help would be appreciated.
MotoX9928,
Are you using a custom mode or the default Armed mode? Do you see any difference in behavior when using a different mode?
Accessing Local Storage
