Hello, I recently unplugged the AC power on one of my cameras and I now have noticed on the app a Yellow Triangle with a lightning bolt. When you go into the camera app setting the battery is a 98% with the battery icon in a red boarder with a exclamation mark. How does one correct the fault?
I have unplugged the ac adapter, rebooted the hub, checked the ac plug to ensure it is plugged in. It is -20 outside so not certain if the cold has anything to do with it.
Any ideas?
IIRC, the yellow triangle when unplugged is a reminder that zones may not work if not on AC power...
The Red triangle with battery is prob that the battery will not charge as it's to cold ( battery does not charge below 32F )
Great thanks for the information TomMac.
Accessing Local Storage
