Arlo Pro multiple locations
I was told by the retailer I bought my Arlo Ulrta with 2 x cameras, that I can use one base station to monitor 2 x different locations with different WiFi networks. Through reading the blogs it appears I will need 2 x base stations - one for each location. Please confirm how I can monitor 2 x locations with Arlo Ultra.
Fred
The cameras have to connect to the hub via the dedicated WiFi. If the distance is too great (different locations), you will need a second hub for that location.
As mentioned above, if distance is to far for cameras, you will need more than one base...
That said, there is no limit on the number of bases ( nor locations ( different states even ) ) you can have on any account. Basically, accounts count cameras for the service level.
Accessing Local Storage
