Activating siren
  • 13 Replies
  • 3118 Views
  • 2 Likes
  • 5 In Conversation
Edinburgh_lad1
I've reconnected my old VMB4500 and now have both 4500 and 5000. However, I can activate the siren on the web for both the 4500 and my Ultras, all at the same time, but when I use the app, only the Ultras sound the alarm. Surely it's not meant be like that, is it?
Thanks in advance.
@ShayneS @StephenB
13 REPLIES 13
ShayneS
@Edinburgh_lad1 Thanks for reporting this, does it occur every time?  let me look in to this to see if I can replicate and I'll report back as soon as possible.
Edinburgh_lad1
I can't check that now because after my base station showed it was online, now it shows as offline. However, I'm awaiting trial firmware so I hope I'll be able to provide more detail.
ShayneS
Thank you
ittroll
Luminary
Luminary
I've just brought my VMB4500 out of retirement to use it as a siren. I performed the case mod detailed a few years ago in these forums to increase the loudness. For some reason the designers put the siren in a sealed box.
I cut a couple of small holes in the feet so I could access the screws without having to remove the rubber.
Arlo Wire-Free, Pro, Pro 2, Go, Q, Q Plus, Baby - You will continue to have access to free 7-day storage even if they enter the EOL stage. For local storage, the VMB4540 supports recording to USB with direct access from the app.
Edinburgh_lad1
@ShayneS
When I want to activate the siren on vmb4500 from within the app, it's not working. My Ultras sound the alarm but not the base station. (Please note that I have both VMB5000 and VMB4500 currently connected and only the former has devices connected to it.)
When I activate the siren via the web, the siren on the Ultras and the siren on VMB4500 activate.
So, something different with the app with the vmb4500 in that it doesn't activate the siren.
ittroll
Luminary
Luminary
It is worth remembering that the Arlo Chime 2 can act as a siren for motion detection. It is only 80dB compared to 100dB from the hub, but it has the flexibility of Wi-Fi rather than requiring a wired network connection.
It is currently on offer at £30 in the UK.
Edinburgh_lad1
How?
Also, it depends on the hub, as the 4500 is definitely not 100db.
It may be 100dB depending on the distance of the mic from the speaker. Distance has to be defined for accuracy.
ittroll
Luminary
Luminary
@Edinburgh_lad1 wrote:
How?
You setup a rule which triggers the Chime 2 siren on motion detection. You can have multiple Chime unts if you wish.
https://kb.arlo.com/000062573/Arlo-Chime-2-FAQ
Yeah, the 4500 has the same 100dB siren as the 4000 but it inside a closed case. So, Arlo's official rating is 90dB. This is why the case mod above is needed to unlock it's full potential. At 80dB the Chime 2 is going to be much quieter than either, but it is compact and perhaps more convenient.
Usually this type of spec assumes 1 meter on axis.
I don't think the VMB4500 produces that much sound (no matter what the spec says).  The siren itself likely does, but the enclosure muffles it.
ittroll
Luminary
Luminary
The sirens on the 4000 and 4500 are visually very similar. In contrast, the Chime 2 uses a speaker.
Edinburgh_lad1
Cheers.
Can you do the same with gen 1 chimes?
I only have gen 1 chimes as they look much better - because of the piece of material - than gen 2 ones.
Edit: I've found this KB but it refers to the old Arlo app: https://www.arlo.com/en_eu/support/faq/000061947/How-do-I-set-up-Arlo-Chime-as-a-siren
I can see, by the way, that users in Europe are being forced onto the new user interface and with new custom modes.
ittroll
Luminary
Luminary
I would think it is possible. If you already have one you are best placed to test it out.
The new UI has been forced upon us for some time. We are still waiting on the proper replacement for a Custom mode to be rolled out. I agree that Chime 1 looks better, the Chime 2 has more sound options and connects direct to Wi-Fi rather than an Arlo hub.
  • 13 Replies
  • 3119 Views
  • 2 Likes
  • 5 In Conversation
