A few questions [Arlo Ultra]
I'm looking at purchasing the Arlo Ultra package but am put off by subscription costs on top of what is already an expensive package.
My questions are;
1) Can I wire all of my cameras (will have 4) so they permanently record?
2) Is there any way to get around a subscription cost? Like saving directly to a local hard drive or something?
3) If I choose to go subscription free am I stuck with only being able to view footage live as it happens or does it save (and accessable) for X amount of days?
Any advice is very much appreciated. Thank you.
My questions are;
1) Yes.
2) Yes. Use the SD card in the hub to record and the app to view the recordings located there.
3) See #2
Accessing Local Storage
