Ultra (3rd Gen) – Local Storage not visible via smartphone or computer.
  • 5 Replies
  • 278 Views
TaSS5257
The Netgear Arlo EOL agent that pressured us to purchase new equipment assured us that the new cameras would work the same (and better) than our old Arlo security cameras.  The new Ultra (3rd Gen) cameras and new Hubs do not allow you to view video recordings on your smart phone or computer.  Arlo has been working on this issue for 5 months and they informed us that others are facing this same issue.  Anyone else having issues viewing video clips via local storage using these new cameras?  Was the issue resolved for you?
5 REPLIES 5
Actually you can see local storage in the app (but not the computer).  But only if you are using a VMB4540 or VMB5000 smarthub.
You need to add storage (microSD card to the VMB5000, flash drive for the VMB4540).  I suggest something in the 128 MB to 512 MB range.  You don't need more than that.
Then you'd set up the storage - the guide here has some steps:
If you want to see the recordings when you are away from home, you'll need to either forward ports in your router to the smarthub, or set up a VPN server in your router.  Some ISPs don't support port forwarding (or charge more for it).  So look into that as well.
TaSS5257
New Case ID 42556060 – Old Case #45501631
Arlo Cameras – Local Storage not visible via smartphone or computer.
Hardware Support, case #45488181
The new camera setup includes the Ultra SmartHub (VMB5000) and high-speed micro-SD card.  The steps in the referenced article were followed during the initial setup.  The only way to view the video clips is to remove the micro-SD card and view the clips on the computer.  Attempting to view the clips via phone only starts a live feed and NOT the recording.
Just wanting to clarify this -
When you go to the feed and and then select local, you should then see a list of clips with gray thumbnails.  If you press on a clip, then it should download to your phone and then play back.
Have you tried this method, or are you just selecting the video from the motion notification?
Note you won't see recordings in my.arlo.com - that is as designed, so not a bug they will fix (though I personally wish they would).
TaSS5257
We were informed by the Netgear Arlo sales agent that our new cameras will in fact record videos locally and we could view them from our smartphone and computer.  Netgear says they have been working for months to resolve this issue, but it looks as though a subscription is needed to view the recorded videos, which reveals deceptive practice on behalf of Netgear.  The new cameras are defective if customers can not view video recordings locally without a subscription.
Based on the customer inquiries noted in this forum, this deception could be viable for a class-action suit against Netgear.
FYI, Arlo was divested by Netgear back in 2018.  Netgear has no ownership stake, they are completely separate company.
I do see local recordings from my Ultra cameras in the app, though there is a bug in the iOS app at the moment (requiring me to go into the base station settings, and then select storage settings).
Do you have a VMB4540 or VMB5000 smarthub?
  • 5 Replies
  • 279 Views
