  • 1179 Views
Ph236
Hi I’d appreciate any help the community can give regarding the following:-
I have two sets of cameras on two different properties using one app.
The first network is using Pro4 cameras the second network Iis using ultra 2 cameras and a smart hub.
If I view live footage on either network will I still get recorded cottage of the live stream?
If not is there any way to achieve recording of the live stream?
Thanks for any help you may give.
Ph236
If you have a subscription, you can always manually record the live stream if you see something that needs to be recorded.
Note that live streaming a camera has no effect on the recording of other cameras.
Ph236
Thanks Stephen,
I was hoping there was an auto record option, but I get your point..
@Ph236 wrote:
Thanks Stephen,
I believe it will detect motion and record when you are livestreaming, but I haven't tested that.  I don't livestream that often.
  • 1180 Views
