two base and 2 diffrent accounts can works with one app ?
  • 2 Replies
  • 476 Views
rehman23
i got one pro 2 hub vmc 4500 with 3 cameras and 2nd hub vbc5000 with 3 cameras ultra pro 2  my question is can i used both base with one app?
for example i setup one email account for vbc5000 ultra2 cameras  and then make separate email account for vbc4500 base and pro 2 camera so i i send inviation add to 5000 to add vmc 4500 can this works with one app if i shuffle option to view both in one app? hope you experts understand my question thanks
rehman23
at the moment i am holding two mobile separately  both base and cameras works fine gives motion alert SHOWING IN FEEDS , so i can send one invitation to 2nd mobile so as i understand in this way one mobile arlo app handle both  thanks
You can use the "Friend" feature to share the cameras between the two accounts.
Are both accounts showing "Library" in the app menu?  Or are they showing "Feed" and "Dashboard" instead?
Both accounts need to match (either both showing "Feed" or both showing "Library").  There is a hack to migrate from "Library" to "Feed", but no way to migrate from "Feed" to "Library".
rehman23
  • 2 Replies
  • 477 Views
