I recently started to experience the error, “Videos stored on Base Station are not available. Please check connection settings.” when trying to access locally stored videos in the Library (I have a VMB5000r5 base station recording to a microSD card).
I have previously been able to access videos with Port Forwarding enabled and also without Port Forwarding when connected to my home network.
I have again disabled Port Forwarding and am connected on my home network, but still receive the same error.
i can see from the storage setting info that my microSD card appears to be saving videos as the amount of space used is increasing.
Anyone else experiencing this error recently? Thanks.
Best answers
If you are still experiencing this symptom, please make sure that the forwarded ports have been setup on the router.
To check if the forwarded ports from the app are open, you can utilize the below port checkers:
https://portchecker.co
https://www.yougetsignal.com/tools/open-ports/
https://canyouseeme.org/If the ports are still closed, the router's firewall or ISP can still be blocking the ports. Please reach out to your ISP or router manufacturer for further assistance.
No, my problem is solved. I had already updated to 5.01 but that did not solve things. I then did an IOS update and that took care of the problem.
The development team is working on the fix for the issue with the remote access. I will provide another update as soon as I have more information related to the release.
Thank you for your patience
is port forwarding working for you? Android or iPhone? I'm on a trail so want to know how it will be after the trail expires and whether it's worth getting more Arlo cams or not.
Nope it is not working on my iPhone and I doubt if it will ever work. If Arlo wanted to fix it, they would have done by now. I would not buy another Arlo camera.
Work on Android, not on iPhone.
On August 30 Arlo moderator wrote that development team is looking into this issue (see list of Best answers).
Let's all cross our fingers and hope this irritating issue will be resolved soon.
I recently received this update from Arlo it has taken them way to long to get to this point.....
We want to notify you that we have identified the underlying cause of the issue reported in case 44138136, and our team is actively working on implementing a fix that will be released shortly.
There is no action required on your part at this time.
We acknowledge the inconvenience this has caused and sincerely appreciate your patience as we diligently work towards resolving the matter as soon as possible.
Sincerely,
The Arlo Team
Thank you. Looking forward to the resolution.
Hello Everyone,
yes I am also very upset with Arlo at times.
in this instance of the problem we are seeing in this thread, my sd card appears to have been corrupted.
swapped out cards and recordings still not being displayed.
i went into my iOS settings for Arlo Secure app and discovered that the “Local Network “ choice had been deactivated by the update.
I turned it back on and viola i can view my recordings again.
this appears to be a very basic item missed in testing new updates from the people changing code and app settings to see the effects of their changes before releasing them into production. I could not see any release notes or warnings during the update so would never suspect a setting in the app would have changed.
anyway I hope this assists many people.
Robert
Hi, suddently I couldn't get remote access to my recordings from the Arlo app. It says "no available" (in Danish though). The port is open (canyouseeme.org), it's forwarded to my Arlo Base Station. I've attached som screenshots. Can anyone help??
Canyouseeme.org:
Port-forwarding in my router:
Error display in my Arlo app
Are you using an iPhone? This is a known bug in the iOS app - it was first reported here in late May.
Hi, yes I use iOS. What do I do then?
esben
Either
- set up a home VPN and use that instead
- wait for Arlo to fix the bug.
Thanks for the tip. Would you maybe have a link to a site with setup instructions?
Any instructions for a home VPN would be in your router's manual. Not all routers support this but many do.
I bought the Ultra 2 bundle from Costco. The free trial expired .
I have been using local storage since day one but since the trial expired i can't access my videos outside of my LAN. I enabled the port forwarding feature in the Arlo app, enabled port forwarding for my router + put the IP address and ports from the Arlo app in my bgw 321 AT&T modem router (Fiberobtics).
I doubled check all the numbers but I still cannot access my videos outside of my LAN.
I called AT&T and they said everything is ok from their side. I callled ARLO they said, call AT&T.
they just send me to each other.
Please note that with the regular cox internet, I have no issue like that and the port forwarding was working very well. I had this issue, when I got the new BGW321 modem 😞
What else is blocking this feature from working properly?
Thank you.
i have several cameras and i am trying to get everyone in my family to get access but it only works on my singular device; VMB5000 with sd card
all other devices access just fine but port forwarding is unavailable on other devices besides one
Hello,
You are getting remote access to your cameras on multiple devices and specifically dealing with port forwarding issues.
First check your IP address verify that the cameras are using the correct IP addresses in their settings and match the forwarded ports. after double-check the port forwarding rules in your router’s settings to ensure they are set up correctly for each camera.
Hope that helps!
The iOs port forwarding issue appears to be fixed (at least for me) with the new release today of 5.01.
Can confirm - yes with the latest update it is now working for me again on iOS.
Hi
I also confirm. Works as intended again(finally) 😀
So what are the benefits of this?
Besides viewing/downloading the videos, do we get smart notifications.
Yep works!!! Even in iOS 18!
FINALLY!!!
Port forwarding still not working for me on my Arlo pro 4 xl Costco version
There is a bug in Arlo's iOS app - port forwarding doesn't work with iPhones at the moment.
I'm glad they apparently have fixed it after so many months. I'm sure there are a lot of people like me that had to move to another camera infrastructure. I had 3 Arlo cameras and Arlo doorbell. I had to replace the entire setup, I just couldn't go months without being able to view videos.
Actually it did work after the latest iOS update ver 5.01
Are all of them sharing your account? Local recordings cannot be shared.
Also, there has been a bug in port forwarding in the iPhone app for some time now (reported in late May). Can you confirm that remote access is still working for you?
Accessing Local Storage
