Ultra2 keep searching in app?
Retired_Member
Not applicable
2024-11-19
03:53 PM
I install app in my 2nd andriod phone devises 4 cam found but keep searching i uninstal app and reboot phone but still showing searching cameras?
If the cameras have already been set up, you can't add them again. Use of a second phone simply means you log in using the same credentials as before and the system should be there with no further action needed.
Arlo Ultra 2
Prima di acquistare
