I just “upgraded” to the Ultra 2 system from my Pro 2 system. Placing my Ultra 2 cameras at the same location of my Pro 2 cameras result in very poor connectivity!!! I contacted customer support and was given the same information to try, verbatim, from the web site troubleshooting guide. No help at all!! The video is not any sharper than the Pro 2 cameras…. What a disappointment, now I’m stuck with this lemon camera system!
Thank you for the info. My plan is to add a second VMB5000 base station via a mesh system. My internet is with Starlink using the Gen 2 Starlink router. My plan is to bypass the Starlink router and set up an Orbi 970 system for the mesh. I have seen numerous posts stating the VMB5000 will not work with an Orbi system. Can you confirm, and if it cannot what mesh satellite system would you recommend that interfaces with the arlo VMB5000 base station?
Don't know where you saw those, but I have two VMB5000s connected to mine. I'm currently using the 860 with two satellites.
Arlo Ultra 2
Prima di acquistare
