Ultra 2 - menu to define absent areas
Je viens d'installer une Arlo Ultra 2 XL et je ne trouve pas le menu pour définir les zones d'activités
Do you have the trial subscription?
If you click on the settings wheel on the camera on the main page of the app, you should see activity zones right under video settings.
If you are using a PC browser (my.arlo.com), then it is inside of video settings (not a separate option).
I don't know what kind of subscription I have but I don't want any subscrption.
I have purchased a SmartHub with SD card that's enough for my needs, no need for a subscription.
I have a Arlo Pro 4 + Arlo Dorbell and for both I can define activitiy zones, the entry is present on both.
But not on the Ultra Pro 2, the entry (activity zones) is not present on the Settings
Although the biggest subscription feature is cloud storage, it is not the only subscription feature. Cloud activity zones (used when the camera is on battery power) also requires the subscription.
The pro 4 supports hardware activity zones when it is AC powered.
But the Ultra 2 does not, so even if you could set them up, you wouldn't be able to get them to work without a subscription.
It's a bit like buying headphones and having to pay a subscription for stereo sound
Nothing justifies the need to pay a subscription to be able to define activity zones
I could understand that a camera would have to be permanently powered in order to use activity zones (like Pro 4) but not pay a subscription
And I can't believe that zones are firstly "analyzed on the cloud" before notifying the user on an Ultra2 while with the Pro4 zones are analyzed right away knowing that Pro4 is advertised as a lower product compared to the Ultra2
I also discovered that I'm unable to share SmartHub SD Card content with a guest and can't understand why (YES appropriate port is open on my router and I'm able to see SmartHub SD recordings from outside of my wifi/network but not my guest) WHY ???
Should I pay a subscription to let my guest view recordings on my SmartHub SD Card ?
Keep in mind that this is a user-to-user forum. I don't work for Arlo.
The subscription would let them see cloud storage, but not the SD card.
I agree it is odd. But it is the case that hardware activity zone processing is not in the Ultra / Ultra 2, but is available on the Pro 3 / Pro 4 (when AC powered).
I will warn my friends/colleagues/family/relatives about issues with these Arlo products
I regret my purchase of these Arlo products but now it's too late to return them
I'll try to sell them on the classifieds because I can't sell them to my relatives
Of course, I don't expect any reaction from Arlo. They have a business model that's maybe acceptable to some people but not to others and I think I shouldn't be the only one upset with the business model adopted by Arlo
Thank you STEPHENB for your answers, I should have been more careful before purchasing these Arlo products ...lesson learned
You're not the only one, many people here are disappointed (and often surprised) at the drop-off in features when the trial subscription expires.
FWIW, I would have made some different choices if I worked for them.
But of course I don't anything about their costs. The cost of providing any cloud features that they offer for free needs to be covered by other revenues (either new camera sales or subscription revenues). And there will be less subscription revenue if more folks are happy with the free features.
Part of the problem is that people spend ~1000 USD on the cameras, and then feel stuck because they can't return them when the trial subscription runs out.
So it's a bit tricky on the business side. I'm thinking that one option for them would be to offer low monthly payments on the cameras if someone commits to a three-year subscription up front. Similar to what US mobile phone operators do.
Arlo Ultra 2
Prima di acquistare
