- In settings how do I set a privacy zone. It states go to zones and select privacy zone but the only option I see is activity zone. My doorbell does have both options however.
@mister-t wrote:
Re: Ultra 2 camera privacy setting
Unfortunately none of the Ultra models have that feature.
Thanks for your reply. Surprised as I thought the Ultra was top of the range and surely its just a software change to enable this feature.
I find it surprising that they didn't at least put it into the Ultra 3.
Not convinced this is "just" a software change. The privacy zones are masked out in both local and cloud recordings, so the mask is being applied in the camera between the sensor capture and the compression. Which is in the middle of the hardware processing chain.
Arlo Ultra 2
Prima di acquistare
