Hello Community, I'm looking for the "total security" mount accessory for my ultra2 but, so far, I've only found available in stock the white version. Do you know if also the black version is available to buy? Thank you
Also looking for the black 'anti-theft' mount (https://www.arlo.com/en-us/accessories/VMA5100-10000S.html) that is needed for the 'ceiling adapter' (https://www.arlo.com/en-us/accessories/FBA1001B-10000S.html).
These products should be described better; nothing really states that one needs the other, and there are no pictures on the website that show them combined.
The ceiling adapter's compatible device list says it is only for the Pro 3 Floodlight camera, not the Ultra. And it is compatible with the mount fhat comes with the Floodlight.
Note that the Floodlight mount is similar to the anti-theft mount - but not the same. It has no anti-theft features. So no idea if the ceiling adapter can be used with the anti-theft mount or not.
Arlo Ultra 2
Prima di acquistare
