Hi I was setting my device up and screwed up the I guess line I am using so I restarted with a new line to use. My question is how do I delete that first line I screwed up on? And also I put the time zone in wrong on the line I am actually using but it will not let me click on it to change it to the right one...how do I correct that issue as well as deleting that first set up line I did. Thanks
Punkie1,
I'm not clear on your description of the issue. I'm not sure what you're referring to when you say "line".
You can adjust time zones within your Arlo Secure mobile app by navigating to Settings > My Devices > select the desired device > Time Zone > select the appropriate Time Zone from the drop down.
Arlo Ultra 2
Prima di acquistare
