  • 1 Reply
  • 410 Views
Kjessler
Hey, my recordings / feeds have stopped working properly. Many of them are frozen or start fine but go all black and green so can see anything. Were all working fine until a couple of weeks ago
Usually this is a network issue (often the wifi connection between the hub and the cameras).  Do you ever have issues with livestreaming?
If the hub is right next to the router, then try moving it as far from the router as the supplied cable can stretch.
Also (as a test) try moving one camera closer to the hub (ideally in the same room, but about 10 feet away).  See if the recordings clear up.
  • 1 Reply
  • 411 Views
