O rings for Ultra 2 Camera & Housing
  • 8 Replies
  • 16278 Views
Sheppeyboy
Luminary
Luminary
Where can I source replacement O rings which are used between Camera & Housing?
Seems many people have asked but no response from Arlo
Sheppeyboy
Luminary
Luminary
As ARLO doesn’t supply O-ring replacements for the ARLO ULTRA 2 camera, I went to a UK supplier of Seals & O-rings etc with the camera and O-ring required, they measured it and found a replacement at £0.20 per O-ring, the replacement O-ring fits perfectly.
Their reference is: 0500-15 NBR70 NITRILE O RING 50mm x 1.5mm
M Barnwell Services Limited
Reginald Road,
Smethwick
West Midlands B67 5AS
United Kingdom
Tel: (0121) 429 8011 (20 Lines)
8 REPLIES 8
Dgmi
Great question!!  there should be an ARLO parts catalog
My equipment is still fairly new, but I can see how some of these items get worn/lost specially after so many in/out cycle when replacing the batteries.
watching this thread, as I’ll prob need some eventually
Sheppeyboy
Luminary
Luminary
MY CAMERAS ARE OVER 2 YEARS OLD AND O RINGS ARE GETTING WORN!
THIS QUESTION HAS BEEN ASKED MANY TIMES AND NO ANSWERS, ARLO DOESN'T KEEP THE O RINGS IS THE USUAL RESPONSE................
More specifically, Arlo has NO replacement parts. Certain things can be replaced by contacting support (requires a subscription) but otherwise you have to search on your own. The local hardware store may be a good source - take your old o-ring or even the camera to see if they have anything that would work.
I recently needed an o-ring that the hardware store didn't have. They suggested a nearby company that had tons of different size o-rings so I went there. They provided me with 2 slightly different sizes to make sure one would work - for free. YMMV.
Same here... found a local hardware store that had a box of assorted o-rings ( for a pro camera )... found one close enough to work.
Tho I do recommend using silicon grease on the o-rings to stop a lot of the wear/tear  ( local hardware, dive shop, pool center, etc ) Only takes a little and stop the camera from sticking inside housing.
Sheppeyboy
Luminary
Luminary
Thanks, I used silicone grease already as a diver use it for my underwater camera etc so familiar with it.
Can find any local o ring suppliers to suit the Arlo though
Try carefully measuring the overall diameter and thickness to see if an Internet search shows anything. They can't be unique.
Sheppeyboy
Luminary
Luminary
Reginald Road,
Smethwick
United Kingdom
Thanks for posting the specs - that should help those needing to replace the o-ring a lot.
  • 8 Replies
  • 16279 Views
