Further, some Arlo cameras can connect directly to your WiFi which is the root of the suggestion to change the new router's WiFi setup to use the old SSID and password so the cameras automatically connect. As said above, cameras connecting to a base or hub don't need this.
You’re mobile device connects to the local wifi router network.
Arlo Ultra 2
Prima di acquistare
