Melbourne
I had to get a new smart hub and since then the camera won't show motion of the cars going past only my driveway and front door
i can't seem to find where to change this now it doesn't detect the cars
These cameras weren't designed to pick up cars at a distance although they frequently do. It's possible that the camera placement isn't the same or that the motion detection sensitivity setting needs to be increased. Generally, the cameras are for detecting people out to maybe 25 feet.
Check that they detect motion generally - either walk across the field of view near the camera and see if it triggers, or use the motion detection test.
Arlo Ultra 2
Prima di acquistare
