Introducing Arlo Ultra 2 - FAQ & Resources
Cutting edge protection for what matters most
While typical security camera footage is infamous for its low fidelity, the Arlo Ultra camera and SmartHub deliver high performance 4K HDR that ensures cutting-edge image quality.
For more information about your Arlo Ultra 2 system and some other helpful resources, check out the links below:
Arlo Knowledge Base
- Arlo Ultra 2 FAQ
- Arlo Ultra and Ultra 2 Product Tour
- What is included in the Arlo Smart 3-month trial?
- What are the features and specifications of the Arlo Ultra and Ultra 2 camera?
- How do I position my Arlo wire-free camera?
- Arlo Ultra 2 Product Page
YouTube
If you have any questions about the Arlo Ultra 2 system, post down below and we'll get to each one as soon as we can. If you need additional help, visit Arlo Support for more articles and resources.
Thank you for being part of the Arlo family!
details on extended range?
current models allow for up to 300' from base station.
My WiFi barely reaches 300' but will the Arlo Ultra 2 still work with base recordings and able to live view from further than 300? Looking for minimum of 350'.
thanks
JehovasFitness,
Your home WiFi range isn't relevant to the Ultra 2's connectivity. Arlo Ultra 2 syncs to the SmartHub so signal strength/quality is dependent on the range and obstructions between the camera and your SmartHub. The maximum distance in terms of line of sight is still 300 feet, but the Ultra 2 camera will perform better than the original Ultra camera under the same conditions due to hardware improvements. As with the original Ultra camera, the conditions in your environment are the most important factor for connectivity. Physical obstructions and interference will reduce the maximum distance the camera can be placed from the SmartHub.
For more information on positioning your camera for best performance, take a look here: How do I position my Arlo wire-free camera?
Thanks and good to know. Am I correct then I wouldn't be able to live view, but could access any triggered events via the Hub w/memory card?
Also, does elevation of the hub make much difference? Like if I put it on the 2nd story would that help achieve max distance?
As well as, is the Ultra smart hub better than previous hubs/base stations for distance, or is that mainly camera dependent?
thanks
JehovasFitness,
If connectivity is poor, you will have issues with both live streaming and triggered events. The camera needs to be able to communicate with the SmartHub to capture recordings and live stream.
Elevating the SmartHub can sometimes improve signal strength but again it really depends on the specific environment. The improvements range improvements with Ultra 2 are based on the camera hardware, not the SmartHub.
Is this a newer generation than my current Arlo Ultra 4k?
If not, why does the post say introducing Arlo Ultra 2?...
Ultra 2 is a new model, just as the Pro 2 (and 3) are newer models of the Pro cameras.
What's the release date for Ultra 2?
Ordered VMS5240 on July 9th direct from Arlo. It appears that this release is dated July 7th:
1) Am I going to see the Ultra or the Ultra 2 cameras? Order is still in the PENDING status as of July 12th.
2) Are there any hardware changes to the base station/hub that I would need to know about?
WeAre911,
Arlo Ultra 2 is available now exclusively at Costco.
Al_FR-153,
The VMS5240 is the original Ultra 2 camera kit. There are no changes to the included SmartHub, but take a look here for a information on camera changes: What is the difference between the Arlo Ultra 2 and Arlo Ultra cameras?
Thanks....They arrived and are as you stated Ultra cameras
Any information about release dates for Europe?
Robi1970,
Not quite yet. Keep an eye on arlo.com for availability announcements.
Order from Costco today and comparing the model number and they seems like the same. Even the firmware are the same
So it looks like these are available on costco and at Best Buy. When will you add an camera only option so we dont have to buy a new HUB if we already have one???? Those options arent available at either retailer. And please dont answer with soon, keep an eye out for announcements. It would be nice to get some actual info for once.
Same question! Not only are my Ultra and Ultra 2 cameras the same, VMC5040s, the VMB5000r5 base stations are the same. I have not taken the time to check if there is dual-band Wi-Fi.
The base stations are the same its the internals of the camera that are different. The dual band is one of the main differences.
This literally might be the most confusing and poorly planned product release I’ve ever seen. Not only is it odd that it’s not available on the Arlo site, but there are no visual indicators that there are any differences between the Arlo Ultra vs Ultra 2. They look the same, feel the same, have the same model numbers, and honestly have similar performance. I put one of the new cameras next to one of the old ones, and there’s literally no performance difference in terms of loading the Live view or using the microphone. What’s the deal?
Robby,
I see no evidence of increased range or dual band Wifi. I have not done a detailed Wifi analysis.
The only difference I can find between the cameras is Ultra: VMC5040 H7 firmware 1.070.50.4_223_df6cd69 vs Ultra "2" VMC5040 H10 1.070.50.4_223_df6cd69 is the Hardware H10 vs H7. Firmware is the same.
The base stations appear to be exactly the same hardware and firmware: VMB5000r5 with firmware 1.16.2.5_633_62dfaa0.
I'm posting this to Costco. They need to figure out if Arlo has actually improved this product or if this is just a marketing scam.
Without forgetting that the community managers/staff are conveniently ignoring the complaints on the forums.
Just bought a set of three Arlo Ultra that Im going to return. The lag is ridiculous, no one seems to be helping on the forums, and I cant even tell whether I own the Ultra or Ultra 2.
Honestly if this brand wasn't owned by Netgear, I would feel like this is all a scam.
I still have 9 days left before I need to return them so Ill monitor the forums until then... but for now it's looking like this I'm reaching the end of my experience with this brand.
Nelchior,
Have you opened a ticket with the Arlo Support team regarding the issue you're experiencing?
The Ultra 2 product page is up and has a pre order other then costco 4 cam kit and an add on cam. It said Oct 18 estimated.
Arlo Ultra 2
Prima di acquistare
