I can connect via my hard wired laptop, but my wirless android can't see the base VMB5000
I just received and started setting my my 2 camera Ultra 2 kit with VMB5000 base station.
I got my laptop to connect and see the base and 2 cameras. The laptop is connected to the router via RJ45 port 1 and the VMB5000 base is connected via RJ45 to the same router in port 2. All good here
My android phone (using the Arlo App) starts the device search and never finds the VMB5000 base. I've tried connecting to the 2.4G and the 5G on the router....both time out when searching.
A
ny ideas- guessing its a NetGear router setting C7000v2, BUT the IP assigned to the phone is in the same network/subnet as the laptop and base?
Is there an Arlo customer support number? Can't find anything that still works since Oct. 2021
Any help would be GREATLY APPRECIATED!
Happy New Year ALL!
Why are you doing this? The cameras are already in your account (and cannot be added to another account). If you use the same account credentials as you used on the laptop, the cameras should just show up.
Arlo Ultra 2
Prima di acquistare
