How do I record backups to both the cloud and the SD card using a VMB5000 SmartHub?
  • 1 Reply
  • 3115 Views
Difraxion
The info I have found makes me think that if I insert the SD card then it won't be using the cloud.I want to keep using the cloud and at the same time have a local backup.
DannyBearAgain
The triggered recordings that go to the cloud are also stored on the base/hub storage device.
Manual recordings and snapshots go to the cloud storage only and are not stored on the base/hub storage device.
Only the arlo hubs allow mobile app access to the local storage device.
https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it-for-Arlo-video-recor...
DannyBearAgain
  • 1 Reply
  • 3116 Views
