Is there a way to move a camera to a different location in the Arlo Secure app? I updated to this app and now my two Smart Hubs are under one location so I cannot arm them separately. One is at a vacation home so I cannot keep them under the same location.
First create a second location (press your profile icon in the upper left of the app, and you'll see a way to add a location).
Second go into the settings for the base on the devices screen. Press the > next to the hub name, and you will move to the "Device Info" screen. Press the location, and you'll be able to change the location of the base.
Note that each location requires its own subscription.
Arlo Ultra 2
Prima di acquistare
