This is a must.
Best answers
@Newcameras wrote:
Can we change the wifi name?Unfortunately you can not.
Note some camera models (for instance the Pro 4) connect directly to your home wifi (without a base), so you could possibly exchange your Ultra for one of those models. Though the Pro 4 is only 2K, not 4K.
Any WiFi connection is relatively easily discovered by someone who wants to. The use of strong encryption and passphrases are what's needed, not "hiding" a connection.
Arlo Ultra 2
Prima di acquistare
