Hello,
background,
ARLO Ultra 2 with base station vmb5000 sub 30months old
have granted access to x2 email addresses and I was able to control this either adding or removing access to either account. (worked fine)
Problem:
I can no longer see the users in my shared user tab (now known as people in the latest updated app) - was an issue before the new app
so I can’t grant or remove access to any cameras for any users nor can I see them to delete them, essentially they don’t exist on my end.
however the users can still see the cameras as per.
solution:
Arlo have given me the run around for the last 4 months on why and steps on fixing it and closing the case and standard trouble shooting on how to grant access…
I find this a massive breach of my privacy albeit I did give these users access however I should be able to delete them, or at the very least remove the access, I just want the users either visible or deleted so I can re add them? Or not
also issues with charging and cameras going off line when plugged into mains, and failing to capture images, Pretty over it.
paying for a sub service and defo feeling isolated and frustrated, looking at changing security brands over this issue, can’t even take back to get ‘repaired’ as 6 months out of warranty, nor will Arlo even offer a discounted subscription for the most part cameras are off line.
You could consider starting over - cancelling the subscription, and removing the cameras and base from the account. Then delete the account, and create a new one - onboarding the cameras again, and resubscribing (after you confirm that the friend access is working properly).
I'm having the same issue that everyone on my "Grant Access" are missing.
Arlo Ultra 2
Prima di acquistare
