Thank you in advance for your answer.
No. If you know when they will be there you can manually disarm the cameras.
well thank you for your answer,
but that is exactly what I don't want to do... having to set it off every time they come in and out of our home.
I they have the app on the phone, and they are logged in the app, and on the same wifi as the home device, why couldn't geofencing also allow people without device to change the mode of the device in their surroundings ?
It could of course, but as @jguerdat says, it doesn't. I am tagging the mods ( @JamesC and @ShayneS ) to make sure they see it, and pass the suggestion on to development.
FWIW, Geofencing sometimes is tempermental, and the more employees you have using it, the more likely it is that one of their devices will mis-report their location (resulting in cameras being disarmed when you don't want them to be).
If the employees have a regular schedule, you could also disarm the cameras on schedule, so you don't have to do anything manually. Though of course if they don't show up, then the cameras would be disarmed with no one on the property.
Arlo Ultra 2
Prima di acquistare
