  • 637 Views
hildekf
Hello,
would it be possible to have the Ultra2 camera setup with the arlo usb cable and a mobile phone plug so that the camera is always charged when active?
Best regards
Karin
hildekf
Thanks for your quick response!
hildekf
Please close the question as it was opened under the wrong camera typ. Its about the Ultra 2 camera!
Yes.  Though if the camera is outside, you should use an outdoor-rated cable and charger.  Arlo sells one, some third parties also sell them.  (I've never used a third party one, so no idea how will they work).
There is also an XL battery upgrade kit available, that will more than double the time between charges.  So that is another possibility.
hildekf
  • 638 Views
