Recently having video playback issues via the app...note that it's only the app as the web portal has no issues. Clearing the cache and reinstalling the app doesn't help. Speedtest, via WiFi, shows Download - 360 Mbps & Upload - 12 Mbps.
When playing videos on the app, the playback pauses constantly and jumps 2-3 seconds at a time (YouTube video link at bottom), which varies by camera and whether you're trying to play it in Dashboard, Devices or Feed. This only affects video playback and not local live streaming. Below I've listed which scenarios/cameras are affected (yes or no). Note that these results are the same regardless of if I'm on the cell network or via WiFi.
DASHBOARD
- Wired Doorbell - YES
- Ultra 2 Camera (2) - YES
- Pro 3 Camera (2) - NO
FEED
- All Cameras & Doorbell - YES
DEVICES
https://www.youtube.com/shorts/YuS7ZaKxmdk
@darkness975 wrote:
You won't see the issue if I do that. Once a video is downloaded it looks fine. The problem is only seen within the app itself.
You could make a screen recording while watching a recorded video, and then provide links to both.
I tried screen recording but it didn't seem to work. Maybe someone else can try and see if it works for them?
@KachinaShadow what type of device are you using?
See post 7:
Moto G Power - Android 11
app version 6.0.0_28852 04/29/25
Though the app might have updated since then.
Thanks for relaying the device info to @BrookeN
@BrookeN
I see you were able to see the screen recording that I provided a link to in both the PM and in my original post of this thread...hope that helps
@darkness975
I was able to do a screen recording on my Android, which showed the issue while playing on the phone...here's how https://support.google.com/android/answer/9075928?hl=en
I then posted it to YouTube https://www.youtube.com/shorts/YuS7ZaKxmdk
Paul
I have passed this information onto our development team. They will investigate this behavior, I will reach out to you as soon as possible with updates.
Having the same cloud playback issue's when viewing on Samsung android phone Arlo app or on HP Chromebook Arlo app. This has been happening since the big update change to the Arlo app.
It's interesting that the video will play correctly If video is played back from the push alert notification, but if you replay the same video from the library it will stutter.
Locally stored video plays cleanly.
Equipment: 3 Ultra 2 cameras and VMB5000 base.
No it isn't. I'm having the same issue after the recent updates.
Arlo continues being the worst product stack of any product category from any company that I've ever used in my entire life.
The software developers at Arlo are some of the most incompetent engineers on the planet.
I am a software engineer, BTW. So I can say this. This is absolutely, 100% a problem with the app, which is and always has been an extremely, extraordinarily buggy piece of garbage.
@BrookeN
Hi Brooke,
Just wanted to make sure you saw the two PM's I sent on 05/17 regarding your question on how the Pro 4 responded.
I picked up some Pro 5s cameras yesterday and will be trying one of them today some time and will let you know if they also have the playback issue in the app.
Paul
I did thank you. I just sent the logs over this morning.
Hi Brooke,
I just realized that I posted this message to you (below in italics) on the wrong thread when it should have been on this one.
You had asked me before, via PM, about whether the Pro 4's (which I have now returned) had displayed the same video playback behavior and I sent you two PM's with that info. I have now picked up some Pro 5s cameras and will be sending you another PM update regarding them...I'm going to include the same chart that I sent in the last PM but with the results of the Pro 5s added so that it will be easier to compare all of the results in one place.
Paul
I experience the same problem with both phones, it is only when I watch the image back in feeds. in the app on the pc on the web it works fine there no stuttering.
Gr Conny
Thought I'd share this list from the PM that I sent to @BrookeN that shows, by camera and playback mode, if it does or doesn't have the playback issue...
YES = has the playback issue
NO= does not have the playback issue...plays smoothly, no hesitations
Pro 5s via “Dashboard” – NO
- Pro 5s via “Feed” – YES
- Pro 5s via "Devices" - NO
- Pro 4 via “Dashboard” – NO
Pro 4 via “Feed” – YES
Pro 4 via “Devices” – NO
Ultra 2 (both) via “Dashboard” – YES
Ultra 2 (both) via “Feed” – YES
Ultra 2 (both) via “Devices” – YES
Pro 3 (both) via “Dashboard” – NO
Pro 3 (both) via “Feed” – YES
Pro 3 (both) via “Devices” – NO
Wired Doorbell via “Dashboard” – YES
Wired Doorbell via “Feed” – YES
Wired Doorbell via “Devices” – YES
Also note that when the playback hesitates, nothing on the screen reacts to an action (whole screen is basically frozen during the few second pauses)...tapping to stop, sliding video to advance or go back to the next video, etc.
Paul
Paying a subscription for poor quality video service is no bueno. If not resolved soon I will drop the service.
So here is a strange update to this. The issue persists to this day. However, if I tap on a video in my library and flip through several videos (left or right direction) the choppy video issue mysteriously disappears and the videos look normal again until I back out to the all videos list and go back in. Then it takes another few swipes for it to look normal again.
I have same issue. It is definitely the app. It started right after the update. I hope there is a solution soon.
Are you still seeing this same behavior? I have not received any videos showing the behavior as of yet, so wanted to reach out and check in.
Can I send you the video directly? I dont want to post my YouTube channel on here.
You can send a link in a private message (PM). Click on the envelope icon in the upper right of the forum page.
Ik kan geen video sturen wanneer hem download is er geen probleem. Alleen wanneer ik hem bij feeds bekijk. Je kan de link sturen naar connyvtpad@gmail.com
Met vriendelijke groet
Conny
I dont speak Dutch.
Link sent
@darkness975 wrote:
I dont speak Dutch.
And that poster does not work for Arlo, so you should not be sending them video.
I wasn't talking to you I was talking to the person that sent a reply in Dutch.
