Cameras wont connect - VMS5740
Hi,
I have a 7 camera system however can only get 3 cameras to connect.
Have tried using auto and manual, however nothing seems to work.
Is there something i am missing?
Thanks!
@SGB28 wrote:I have a 7 camera system however can only get 3 cameras to connect.
If you are trying to onboard them all in the app, then I suggest switching to a PC (my.arlo.com). Ideally connect the PC to the router with wired ethernet.
Arlo Ultra 2
Prima di acquistare
