CVR is not support on this device error message
When going onto the app timeline, I get a warning saying "CVR is not supported on this device".
Does this mean the camera (Ultra 2), or it isn't supported on any three of my Android devices?
It should be supported on the camera (and viewable on the Android devices).
Do you have a CVR subscription for the camera? Is it AC powered?
Yes, I have a subscription for each camera, and both are connected to power.
Right, as it just so happens I just check again on my timeline but now it's telling me I need to upgrade 😞
That's nice after paying 😕
Upgrade what?
When I click timeline, it says
"Add CVR plan to your camera to use the timeline feature"
"Upgrade"
@AndyGB wrote:When I click timeline, it says
"Upgrade"
Have you doubled checked that the cam is active on CVR in your subscription setting.
Arlo Ultra 2
Prima di acquistare
