@rozzamac15 wrote:
How do I store and access my 4K videos locally instead of paying for expensive subscriptions?
If you want to access the 4K videos from the app, then you need a smarthub (VMB4540 or VMB5000). Then you can set up direct access to local storage: https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
There are some limitations you should be aware of:
- Recordings only accessible in the app (not the browser)
- Recordings only accessible to the primary account (not friend accounts)
- No Manual Recordings or Snapshots
- No thumbnails
- Remote access requires router setup (either port forwarding or a home VPN), which some find difficult.
- No thumbnails
Arlo Ultra 2
Prima di acquistare
