Arlo ultra 2 do I need a subcription to view library
  • 1 Reply
  • 772 Views
duramax3
Do I need a subscription to view library on arlo ultra 2 camera's
You need a subscription to get any cloud storage.
Though if you have a smarthub, you could alternatively add storage to the smarthub and use direct access to local storage.  https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
That does have some limitations though:
  • You can only see local recordings from the app (not the browser)
  • You can only see local recordings from primary account (not friend accounts)
  • You cannot save manual recordings or snapshots
  • There are no thumbnails
  • Remote access requires changes to your router setup, which some find difficult.
Note that a subscription is also needed for smart notifications and for cloud activity zones.
  • 1 Reply
  • 773 Views
