Can anyone help I ordered some ultra XL cameras and can’t find any silicone skins in the UK. Have tried Arlo they say they don’t supply them, none on e bay or Amazon.
Only ones I found were wasserstein the website says they are in stock and when you purchase them you get an e mail saying they can’t fulfil the order and refund you the money.
The only ones I can find are in the USA. Please can anyone help happy to buy second hand just want to protect my new cameras.
Thanks Ben
Be careful here. Arlo has some skins for the Essential Gen 2, but they do NOT fit the Essential Gen 2 XL (or the older Essential cameras).
Thanks do you know where I can get the xl skins from ?
No. I've seen the Wasserstein ones, but haven't seen any other options.
FWIW, I don't use skins on my own XL cameras.
I have the same problem and mistakenly bought some non XL skins. The only ones I can see are Wasserstein and are available in the USA only. I guess someone will start producing them in due course or Wasserstein will make them available here.
Arlo Ultra 2
Prima di acquistare
