So I’ve had the VMB4000r3 base station with Pro cameras for a while - no subscription because the 7 days worth of recordings were just fine. Sometime aroun January 2022 - I wanted to start upgrading the cameras from Pros to Ultra for the better quality. So I did …. However, on two different base stations (Vmb4000r3) and two different ultra cameras the recordings just stopped and I no longer have my recordings available. Does the 7 day no longer work after the trial period? Funny part is, the Best Buy salesman assured me that it would be just fine.
is it true that once the trial ends so does the recordings? I even purchased a 1
Thanks. Unfortunately that was one of the reasons I chose Arlo over Ring. Looks like I’ll be getting rid of the Ultras and go back to Pros. Sad that companies are forcing people into a non value added service.
I have 6 Arlo Ultra cameras that came with a year subscription. Once that subscription ended I lost the ability to save any recordings, locally or not, lost access to any local recordings I had on my micro SD card (from the app,) and most definitely do not have the ability to use the motion detection to initiate recording.
This company is a disgusting excuse for a user friendly experience or business. Their support is as well.
They are concerned with one thing, making money. I have no clue why anyone still uses Arlo or would pay for a subscription to record video locally on a system with devices you paid in full for. On top of that why would one pay Arlo for support on issues that have existed before my subscription or warranty ended? The default answer Arlo supplies is "I suggest you pay for the $2.99 subscription solely for technical support then cancel it."
Everything mentioned is completely unacceptable behavior.
You must have the VMB5000 base if you use a microSD card.
Are you seeing the option to configure direct access to local storage in the app? If so, what happens when you do that?
Arlo Ultra 2
Prima di acquistare
