Arlo Hub VBM5000 Feed to App slow and needs many refreshes
  • 890 Views
mrjcjones
Arlo Hub VBM5000 local storage Feed to App slow and needs many refreshes of the App screen before the Feed loads to the phone.
Can I do anything to improve the immediacy of the data feed to the phone app?
Everything else seems to be working well.  I have 2 Arlo Ultra 2 cameras, 1 wireless doorbell, and the Hub with local storage.
mrjcjones
I had a Linksys mesh sytem attached to a main router.  In the setup instructions I was advised to use only the mesh wifi and switch off  the main router wifi to avoid wifi conflicts.
As a trial I switched the main router wifi back on and attached the Hub to the  main router and the speed of response from the Hub was much improved.
Learning point: don't always believe what you are told!
Thanks for your reply.
ShayneS
Are you still experiencing this symptom?
May I ask which troubleshooting steps you have tried so far? I don't want to suggest anything you have previously performed.
mrjcjones
ShayneS
@mrjcjones
Thanks for the update.
  • 891 Views
