It is rather inconvenient to have to take the camera housing down in order to recharge the XL battery. I wanted to see if there are plans for a separate charging mechanism or a dual charger so I could just swap out one XL battery with a charged one, as you can do with the regular batteries?
jparker1172,
Standard or XL batteries can be charged using the Arlo Dual Charging Station. Take a look here: Dual Charging Station
jparker1172,
Thanks, James! I didn't realize the XL's would fit until I received them at home and saw they are the same base dimensions. Arlo should consider adding that in the description for the dual charger! Just makes it easier for people who are new to Arlo in learning what they need to purchase at start up.
Arlo Ultra 2
Prima di acquistare
